Login Error
Close
Replacing Shower Curtain Rods
by DoItYourself Staff
what you'll need
  • Clean cloths
  • Cleaning agent such as 409
  • Sponge
  • New shower curtain rod
  • New shower curtain rod brackets
  • Step ladder
  • Screwdriver
  • Hammer
  • Spackling compound
  • Spatula
One way to update your bathroom is to replace older shower curtain rods with something new and trendy.
In other words, it may be time to take down the boring shower curtain rod that has been sitting in the same spot all of these years. Purchasing a new shower curtain rod can immediately change the appearance of your bathroom and update it without much expense.
Measure Area
Be sure you measure the old shower curtain rod and the area where it will be going before heading to the store.
Choose Style
Bathroom shower curtain rods are available in various colors and finishes such as stainless steel, brushed nickel or even solid colors. There are also simple vinyl casings that can cover the old shower curtain rod quickly and inexpensively. These casings can also be removed and changed frequently.
Here is how to replaces a shower curtain rod.
Step #1: Remove Old Rod
If you have a shower curtain rod that is on a spring, simple pop one end off the wall and then slide the shower curtain and the shower rings off that are holding the curtain in place off the rod.
Step #2 Clean Areas
Next, use a clean cloth and general cleaning agent to clean the areas before installing a new shower curtain rod. It is important the area is clean and free of debris remaining in order for a new rod to stay in place.
Step #3: Unwrap and Place
Unwrap the new rod and take one end in hand, while holding the other end. Release the spring and let it adhere itself to one of the walls of the shower, at the same time, bring the other end up and place at the opposite end. Springer rods can usually expand and fit the area as needed. They are usually packaged under compression and will expand when unpacked. The twist easily to make them longer or shorter.
Step #4: Permanent Rod Changes
If you have a permanent shower rod in place that is not a spring rod, it will take a little more effort. Most permanent rods are installed on brackets that adhere to wallboard. You can completely unscrew the old brackets, replace with new ones or keep the current brackets for a new rod.
Step #: Remove Brackets
Unscrew old brackets and re-install the new ones chosen by fastening with screws. You might have to fill in old holes and then drill new holes if the originals are stripped and cannot hold new hardware. Use spackling compound spread with a paint spatula and let it dry completely, possibly the next day before placing new screws.
Step #6: Creative Casings
If you have chosen to simply place a new casing in a different color or design over the older rod, follow steps 1-3 and then cover the older rod with the new casing. Change as often as you like.
 forum activity
