Resurfacing Marble Bathroom Countertops
what you'll need
- Sealant
- Polish
- Diamond Cutter
If you want to spice up your bathroom counter tops with a simple DIY project, consider resurfacing marble bathroom counter tops to create an entirely new look for your bathroom. The following is a guide to resurfacing marble bathroom counter tops that will restore their beauty. The surface of any marble bathroom counter top is capable of being resurfaced after it has become dulled, and if you need to resurface your marble bathroom counter top, the following step by step instructions will help you immensely.
Step #1: Understand the Process
The process involved in resurfacing a marble bathroom counter top involves removing a very thin layer right off of the surface of the counter top. The most common tool used for this purpose is a diamond cutter, which is used to remove a very thin layer from the very surface of the marble bathroom counter top. Once this has been completed, the marble is shinier and clean again, and you can polish and seal the counter top to make sure that it continues to be shiny and beautiful for many years to come.
Step #2: Remove the Surface
The very outside of the surface of the marble bathroom counter top is what has become dull with time. The marble underneath is still beautiful. Using a Diamond Cutter or some other type of sander, you can remove the very outside layer of your marble bathroom counter top in order to restore the beautiful look that it once had. Once an inner layer of your marble bathroom counter top is revealed, its beauty will return without the dull appearance that your marble bathroom counter top previously had.
Step #3: Polish the Surface
Now that your marble bathroom counter top has a shiny new surface, you should apply a polish intended for the marble bathroom counter top material to make it even shinier and to really bring it to life. This will restore the beauty and shine of the counter top. Before completing the polishing of your counter, be sure to have the sealant product readily on hand because the sealant should be applied as quickly as possible.
Step #4: Apply the Sealant
The sealant, when applied to your marble bathroom counter top, seals in the shine and helps to protect your counter top for dulling or the look of aging. Be sure to choose the correct sealant by talking to the salesperson before purchasing.
