Login Error
Close
Reverse Osmosis Water Purification System Maintenance
by DoItYourself Staff
Reverse osmosis water purification systems are a great way to clean your home’s water. These systems are inexpensive to easy to install. They are effective purification methods, but, like any purification system , occasional maintenance is needed so that your drinking water remains clean. This guide will explain how to properly care for your reverse osmosis water purification system.
Prefilters
Fortunately, RO purification systems need very little work to maintain. Most systems only require their pre-filters to be changed every 6 to 12 months. Filters can be purchased at most home improvement stores, just make sure to check your manufacturor’s specifications so that you buy the correct filters.
In order to replace, find the old pre-filters and remove them. This can be done without any tools because they should slide out easily, Then, you can place the new filters into place, they should slide in easily.
Osmosis Filter
Depending on the model of RO purification system that you have, the main osmosis filter should be changed every 4 to 7 years. If you notice that the taste or appearance of your tap water has changed, then it you should probably check the osmosis filter. If it looks dirty, contact your manufacturer for a replacement.
 forum activity
