Roll-Out Garage Flooring: Pros and Cons
Roll-out garage flooring is a type of flooring surface that has become popular in garages in recent years. It provides an alternative to garage tiles or painting the floor. Consider the following pros and cons of roll-out garage flooring to determine whether it is right for your needs.
Advantages of Roll-Out Garage Flooring
One of the advantages of this type of flooring is that it is relatively easy to install. Since it comes in one large sheet, you can roll it out and then attach it to the floor. You do not have to worry about working with individual tiles.
Another benefit of this type of flooring is that you will not have to deal with a lot of seams. You will probably have one or two long seams in the flooring, but you will not have nearly as many intersections as you would with tile.
Disadvantages of Roll-Out Garage Flooring
One of the potential drawbacks of this type of flooring is that it can be costly. It will cost more than painting the floor, and it could potentially cost more than tile, depending on what brand you buy.
Another problem is that roll-out flooring can be bulky and heavy when transporting it into the garage. This can make it difficult to move when you originally install it.
