Login Error
Close
Roof Flashing Repair for Rubber Roofing: Mistakes to Avoid
by DoItYourself Staff
When doing roof flashing repair on rubber roofs, prevent leaks by avoiding these common mistakes.
Avoid Cutting Rubber Roof Flashing too Shallowly
Cut the rubber flashing generously so it overlaps the roof valley, vent or eaves by 12 inches per side.
Avoid Wrinkling the Flashing
Remove the protective backing film in one motion from the flashing and install it smoothly on the surface. Avoid creating wrinkles and bubbles which can trap water.
Tape Edges Generously
Apply termination sealing tape over the top and bottom edges of rubber roof flashing so it reaches 1 inch beyond each end, to avoid peeling and lifting of the flashing.
Avoid Gaps and Buckling around Vents and Chimneys
Roof leaks are most common around vents, skylights and chimneys. Measure the rubber flashing carefully for a precise fit and seal edges snugly and smoothly with the termination tape. Apply a coat of liquid EPDM (ethylene propylene diene monomer) to all flashing edges after they are taped for true watertight coverage.
Avoid Cheap Roofing Caulk
Find the best roofing caulk you can use, avoiding those that break down in UV light. Look for roofing caulk with UV protectant.
Apply Rubber Roof Flashing in Mild Weather
Avoid applying rubber roof flashing in temperatures below 55 degrees F. The adhesives cure and seal most effectively above 60 degrees F.
 forum activity
