Rotary Grater
A rotary grater can make easy work of shredding all types of foods for cooking. A manual box grater can be dangerous, but a rotary grater is completely safe. Here is why many people choose a rotary grater over a box grater.
Why Buy a Rotary Grater
If you ever like to grate cheeses or other foods at the table, then you really should invest in a small rotary grater. You are sure to delight your guest by offering them fresh grated Parmesan or chocolate shavings right at the table and a rotary grater makes this job easy and virtually mess proof.
If you go too quickly or try to grate a piece of food too small on a box grater, you are likely to also grate your fingers. A rotary grater is designed so you can grate even the smallest pieces without your fingers ever coming close to the blade. A rotary grater is also much preferred when trying to grate soft foods like hard boiled eggs.
There is a rotary grater specially designed to grate specific foods like ginger or soft cheeses. A rotary grater makes for very even and attractive grating even with very small pieces of food. Be sure to purchase a rotary grater with removable parts so that it is easy to clean.
