Login Error
Close
Rubber Roof Slate vs Real Roof Slate
by DoItYourself Staff
Rubber roof slate is a convenient alternative to real slate. Originally, rubber was mainly used for repair work on roofs. However, developments in the roofing sector have added rubber to the growing list of roofing materials. Traditionally, rubber has been used as a suitable alternative to asphalt on flat and gently sloping roofs. Today, it is even used on steeper roofs. Rubber roofing is produced in various styles. It can be manufactured to resemble slate, tiles, cedar and asphalt. Below is a comparison between rubber roof slate and real roof slate.
Pros of Rubber Roof Slate
Rubber is one of the best eco-friendly materials for construction. Rubber roofing is made of 80 to 100 percent recycled material. This makes it an ideal choice for those keen on green alternatives in roofing. Rubber also has an excellent insulation capacity. This helps control heating and cooling in the house. Rubber promotes energy efficiency. You will benefit from reduced power bills with a rubber roof in place.
Rubber slates are affordable compared to other roofing varieties. You can get your roof to resemble most of the other materials yet at a cheaper cost. With rubber roofing, you are guaranteed durability. It is fire resistant, wind resistant, bug resistant and waterproof. Many rubber roofs are designed to last up to 50 years. Rubber roofing doesn’t require much maintenance to retain its appearance. Yet it keeps its good looks for a long time.
Cons of Rubber Roof Slate
Installation of a rubber roof is an entailing process. Much technical knowledge is required for proper installation. It is best that a trained roofer does the job. This will ensure you of best results. Rubber roofing is perhaps the most recent development in roofing materials. Not many qualified roofers may be well-versed in installation. This often pushes up installation charges.
Pros of Real Roof Slate
A slate roof gives your house an elegant and classical appearance. You can get a much wider choice in color, texture, appearance and style with slate roofing. Rubber roof slates will not give you as much variety as real roof slate. Slate, unlike rubber, has been used in construction for hundreds of years. This has enabled a wider choice in final product. Since slate is heavier than rubber it guarantees you a stronger house with higher stability. Slate roofs are more durable than rubber slates. Slate is waterproof, resistant to fire, storm and winds. A well-installed real slate roof will last up to 100 years. This is about twice the life span of a slate rubber roof.
Cons of Real Roof Slate
Slate roofing is costly to install. It is best to have a qualified roofer install as slate is a highly specialized roofing type. However, the results are well worth the expenditure. Frequent maintenance is necessary to maintain the integrity of real roof slate. This pushes up your overall costs. Unlike rubber, slate is very heavy. This calls for more labor during installation, again adding to overall costs.
 forum activity
