Rustic Log Fireplace Mantel Installation Tips
To help you in installing your log fireplace mantel, here are some tips that you can use for an easier job.
Importance of a Scribe
If you are installing a mantel for your log fireplace yourself, attaching a scribe or wooden beam will make it easier to attach a wooden mantle instead of trying to nail them directly into stone or concrete. Make sure that you have the time and money for the project since the more sophisticated the materials are, the greater the amount of work that you will have to do.
Taking Your Marks
Taking the time to mark the wall with a pencil is essential in keeping your boards and mantel level. Create horizontal notches that are twelve inches apart to mark the spots where the top of the shelf meets with the wall.
Making Your Fireplace Safe and Legal
In installing a log fireplace mantel you need to consult the guide mandated by the Fire Code of the National Fire protection Association. This will allow you to know the current fire code regulations related to the construction and improvement of fireplaces. You also need to follow local and national regulations in order to satisfy your home insurance requirements. But regardless of codes or regulations, you need to install your mantel high enough to prevent it from catching fire.
