Satin Paint vs Eggshell Paint Satin Paint vs Eggshell Paint
While eggshell paint is slightly reflective and works well on most walls, satin paint has a silky finish and is perfect for kitchens, bathrooms, and more. Both paints have their own distinctive qualities that make them wonderful choices for redecorating or repainting your home. Although satin and eggshell paint are only two of the paint-type choices, they are some of the most used and well-loved.
Satin Paint
Appearance
Satin paint isn’t an ultra-shiny paint, rather it has subdued reflective characteristics. Many have said that it even adds a slight glow to walls, calling it “velvety.” One of the most popular paint choices, satin paint is often preferred over flat paints because it gives the walls a feeling of greater depth.
Durability
Satin paint is a preferred paint because it is durable enough to hold up to the natural wear and tear of walls in a family home. Once dry, this highly durable paint can be washed, making it a suitable choice for multiple types of rooms, including kid’s rooms, bathrooms, foyers, and kitchen areas. It also works well as trim and woodwork paint.
Although it is washable, it’s advisable to not scrub the paint too hard or too often, for it won’t hold up to harsh abrasives for long. Cleaning satin-painted walls this way could take its shine away.
Satin paint can almost always be used for both interior and exterior use, but check the directions on your specific brand because some are specially formulated for one or the other.
Downfalls
Although satin paint is growing in popularity with homeowners, especially for its low-coat application process, this paint easily shows application flaws, making touch-ups a tricky. If not applied with a careful hand, you will be able to see brush and roller strokes left behind.
Eggshell Paint
Appearance
Eggshell paint is often chosen for its smooth sheen and feel that is comparable to the object of its name — an eggshell. Although it is not as reflective as satin, it is more reflective than flat paints and often used for decorative finishes. Eggshell paint is referred to as having a little luster, rather than being shiny. Note that the exact sheen can be slightly different between various manufacturers.
Durability
Eggshell paint, although not as durable as satin paint, is still a better choice than flat paint for high-traffic areas. While it won’t suit every room, this low-luster paint is a safe choice for most walls in the house, especially if you don’t have younger children. Although most eggshell paints are to be used inside the home, there are a few brands that say it can also be used for exterior walls.
Downfalls
Although eggshell paint covers imperfections well after about two coats, this paint should not be used for areas like kitchens, bathrooms, or children’s rooms because it will show scuffs and is not as durable as other paints, like satin. To lessen this possibility, make sure you know how to properly use your eggshell paint.
While eggshell and satin paints are both superior paint finishes, they each have their own perks and downfalls. You should decide which kind to use based on your specific needs.
Topics:
DIY basics
