Save Money on Your Energy Bill by Updating Your Insulating Ducts
Insulating ducts can be quite a challenge if you are unaware of the different types of air ducts and insulation that there are. You will need to do your homework and understand that each job is different. With each job, you may require a different form of insulation.
Fiber Glass Duct Board Ducts
The fiber glass duct board ducts are by far the most effective. There is an insulation that is free of formaldehyde that also has an acrylic coating. This coating will help keep the glass fibers from your airstream. This will help to keep your home from excess noise. You will also be able to have a much better type of air quality. This type of duct will be a little bit more expensive to install, so it is not the most popular method. You will need to keep in mind that you may have to pay a little more than you want in order to get your home filled with clean air and free of unwanted noise.
Round Sheet Metal Ducts
These un-insulated rectangular ducts are also known as round sheet metal ducts and are the most popular type. While they are very inexpensive to install, they are not very effective. You will find that not only are they prone to allow excess noise in your home, but they also are known for condensation, as well as air leakage. If you do choose to use these, there are ways around them to make them more effective. You will need to wrap them in an external insulation. This will help to improve the overall performance and get them working the way that they should. Any type of air duct that you get can always benefit from external insulation. Typically, this form insulation is not very expensive and installing it is not too difficult. This will not make the ducts work as well as the aforementioned ducts, but it will help in their overall performance.
Basic Ductwork
It is important that you have at least a basic understanding for duct work when you are working on them. The more that you know, the better off you will be when it comes to picking the right type for your home and the specific area that they are going into. Both hot and cold air will need to be absorbed enough so that your home stays at a comfortable temperature year round.
There are three duct classifications. The first is the conditioned air duct. This will carry all of the air that is conditioned from your air conditioner. It will then disperse this air back into the system. Fresh air ducts will focus on the fresh air in your air conditioning system. A round duct is the most effective. You will need less material than you would for a rectangular or a square duct.
