cancel
Job type :
Zip Code :
community forums
comments
Screed
A screed is a flat, straight tool used for the purpose of leveling and smoothing concrete or other building materials.
What Options are Available to use as a Screed?
Any number of objects can be used as a Screed. In the past, no specific tool existed for this purpose so people would frequently use wooden beams to smooth the concrete. This method has a number of problems related to it. Wood tends to be a bit on the heavy side and since the tool will often need to be ten feet or longer; this leads to the need for two people to generally hold the screed.
Wood will also warp over time as it is exposed to concrete which eventually leads to the tool no longer functioning for its purpose. In recent years an aluminum screed was released on the market offering handles and a significantly lighter weight. This aluminum screed weighs twelve pounds at 10 feet in length so it is easily operated by one user. It also has handles to offer an easier grip, and does not warp over time.
member comments
Related Articles
How To Screed Cement
When you screed cement you are essentially making the cement flat... read more
Different Kinds of Workbenches
This article discusses 10 different workshop workbench options, including toolboxes, tool pouches, caddies and work... read more
Tips on Screeding Concrete Floor
Screeding is the art of skimming freshly poured concrete floors and other surfaces... read more
articles we like
DIY Landscaping Gravel
Many times landscape gravel is seen as underlying foundation or as a temporary fix but... read more
Transom Window
A transom window is a common feature in modern homes. The window rests over the... read more
Get an edge in the job market with a graduate degreeGet an edge in the job market with a graduate degree
In a tough job market, holders of graduate degrees, such as master's or doctorate degrees,... read more
sponsored articles of the day
diy centers
