Sectional Garage Door Options
When choosing a Sectional Garage Door, there are a few things that you may want to consider. Here is a quick guide to a couple different options, to help decide which is best for you and the situation you live in.
Steel
Steel is a very common material for a garage door. The reason for this is that it is extremely sturdy and weather resistant. Two things that you will want to consider when looking into a sectional steel door for your garage are the paint or finish and the thickness. Depending on the climate you live in, you may need a few coats of finish to protect from rust. The upside to a steel door is that it is very sturdy and gives off a sleek look. The problem comes in if you have a lower budget.
Wood
Wood is also a common material used for sectional garage doors. The wood garage door is a classic look and can be painted and finished as you would like. This is a less expensive option than the steel door, however you may find problems with wear and tear, especially if you live in a place that experiences a high amount of rain and snow.
