Sediment Water Filter
Sediment water filter designs are meant to remove certain contaminants from potable water as it flows into a home or business.
Types of sediment water filters
A sediment water filter can come in several different designs. It might be used for:
- Faucet use only – In this case, a sediment water filter will be hooked up to a faucet-based system for cleaning drinking water before it flows out of a tap.
- Whole house systems – Sediment water filters may also be attached to larger water purification systems that are designed to protect a whole house from large particles clogging taps and appliances.
Why a sediment water filter might be needed
A sediment water filter system might be in order in a number of different circumstances. The common reasons homeowners and businesses install sediment water filters include:
- Visible presence of large particles – When water coming into a home is filled with large particles, such as sand, grit or minerals, a sediment water filter can help remove them.
- Concerns about particles – Some people prefer to have a sediment water filter installed just to be safe. Well users, for example, might want the extra layer of protection provided by sediment water filters.
