Selecting an Energy Efficient Pool Pump: 6 Tips
Whether you are replacing an existing pool pump or require one for a new pool, it can be useful to know what to look for in an energy efficient model. Think about the few tips below as you shop for an eco-friendly appliance that can save you money.
Speed
Many older varieties of pool pump will have only 1 speed, but this is an inefficient way for it to work. Opt for a pump that has a variable speed control that will enable you to reduce the speed of a cycle for the appliance. This process will allow water to filter through the system once every 24 hours, which is more efficient than reducing the time the cycle takes to run so that you can also save money. Your controlling the speed of the cycles will stop the pump from having to work too hard.
Materials
Check the materials that the pool pump are made from to ensure that they are non-corrosive. This will reduce the risk of any components developing rust and reducing the ability of the pump working properly. Remember that you get what you pay for and a pump made from reinforced materials are likely to cost more, but will be a more efficient option as it will last longer.
Access
Examine the pool pump before purchase to figure out how easy it would be to access the filter and grate once it is in situ. A pump with components that are easy to access will be cleaned more often, which will help it to run more efficiently as it will not have to work too hard due to a build up of debris.
Wattage
The amount of watts that the pump requires to power it must be taken into account as this will affect how energy efficient it is. It is not necessary for the pump to use a significant amount of energy to make it work so choose a low wattage option.
Control
A pool pump that comprises a digital control will allow you to set it so that the cycle runs during off-peak periods for demands of electricity. The costs during these times will often be cheaper and you should check with your utility supplier for confirmation of the precise times as they will often be during the night. Alternatively, choose an option that has a timer which will do the same job.
Size
When selecting a pump, bear in mind the size of your pool to help you decide which is best for your purposes. A significant amount of energy can be wasted if an incorrect sized pump is used. If the pump is too small for the pool, it will be forced to work too hard to filter the water which will not only waste power but can also cause the pump to break down. Where the pump is too large, it will waste energy the moment that it is turned on.
