Selecting Sauna Wood: The Best Types
Selecting the perfect type of sauna wood is essential for the overall sauna design. The wood should be a soft wood that will absorb the heat which is emitted from the steam. There are many different types of wood that can be used for a sauna construction.
Spruce
Spruce is used to create a Nordic designed sauna which is found in Finnish areas. Spruce is a white wood with fine grains and light small knots in its design. Spruce will darken slightly over its lifetime but will generally remain a light wood. Spruce is amongst the more cost-effective wood used for building a sauna.
Pine
White pine can also be used and when it is new, it will look similar to Nordic spruce. Pine has larger knots in it which will fall out when the wood becomes dry. To prolong the knots, pine should be treated when being used as a sauna wood.
Cedar
Cedar wood is a very popular choice of sauna wood because of its light appearance and its resilience to decay but it is more expensive than other woods. Cedar has a natural aroma which can be very pleasant during a sauna and it will cope extremely well with the increased temperatures within the steam room.
