Login Error
Close
Selecting the Right Wireless Home Security Camera Systems
by DoItYourself Staff
When trying to pick between wireless home security camera systems, there are a number of factors you need to consider before you make a decision that will involve the security of your home.
5 things to consider when researching wireless home security camera systems:
  1. Check the range on the wireless camera system. Models range from 100 feet up to over 500 feet. For smaller homes, 100 feet should be plenty. Larger homes may need a significantly higher range.
  2. Verify how your home's construction will affect the functional range of the camera system. Homes made with wood and plywood exterior walls will interfere less with the signal than homes made from metals, concrete or brick. These factors can reduce the effective range considerably, so it may become necessary to purchase a system with a greater range.
  3. Find wireless home security camera systems which can support enough cameras for your needs. Systems range from 4 to 30.
  4. Be aware that 900MHz and 2.4GHz phones may interfere with certain systems.
  5. Check which cameras offer low-light visibility. Some locations may not require this feature while others may need it to be effective.
Taking these considerations into account will help you to select a wireless home security camera system that will meet your specific needs and function properly in your home.
 forum activity
