Login Error
Close
Semi Gloss Paint vs Satin Paint
by DoItYourself Staff
The article compares semi gloss paint and satin paint. Paints come in various varieties and many include gloss in them. The quantity of gloss varies in each of these. The quantity leads to a different specular reflection for each type of paint. The comparison is made by explaining the characteristics of the paints, its uses, methods of applying, cost and there on.
Semi-gloss paint is most commonly used on doors, cabinets, trim, and bathrooms as it can be easily cleaned without losing its shine. These paints are also great for busy traffic areas as they are strain-resistant. The paint results in a subtle shine and is not very ostentatious. The most important disadvantage of using this type of paint is that it cannot hide minor blemishes of the surface.
The satin paint is also commonly known as eggshell paint and low sheen paint. It has a delicate, smooth, soft, and glossy look that has properties to hold up to light scrubbing. The paint gets its name from the fact that the paint has the shine and luster of a fresh eggshell.
Characteristics: Semi gloss paint when dry has a rich shine and shows even the minutest of imperfections like bumps or dips on the surface. In comparison, satin paint leaves a shinier finish as compared to semi gloss paint. In addition to this, satin paint is more flexible and can fake finish surfaces.
Theoretically: Semi gloss paint is 50 per cent gloss of paint while satin paint is 30 per cent gloss of paint.
Uses: Semi gloss paint is used in bathrooms, cabinets, and in kitchens as it is easy to wash and clean. Moreover, it gives a subtle shine and not a glitzy look that makes it perfect to use in such areas. Satin paint has a velvet touch with gloss and is used for ceilings, windows, doors and walls. This paint is popular in children rooms.
Cost Factor: Semi gloss paint is costlier than most other paints as it is durable, results in a fine gleam and washes up easily. Moreover, it resists all dust stains and smear very well. Comparatively, satin paint has a crystal clear shine, is not durable, and cannot be easily cleaned. This makes it less popular and less costly as well.
Reflective and Non-Reflective way: Semi gloss paint has a nature of giving a very shiny finish, and is more reflective of blemishes in the surface. On the other hand, satin paint being is non-reflective and can smoothen the surface. The paint can cover up the bumpy and defective surfaces
Washable and Performance: As mentioned above, semi gloss paint is easier to wash than satin paints. Additionally, semi gloss paint is much more durable as compared to satin paint.
Both the paints can be applied on all surfaces including walls, ceilings, furniture, stair-cases, etc. Selecting the right paint for your room can be a confusing task and must be done by keeping certain pointers in mind. These include the final appearance, light reflection from the finish, durability, and suitability for the particular area.
 forum activity
