Separating Whites, Colors and Delicates in the Washing Machine
The washing machine is a great invention that allows us to clean our clothes with little effort, in a short period of time. Maximize the performance of your washer by separating clothing by color, using stain remover, properly loading the machine and adding the right detergent.
Separating the Laundry
When washing clothes, protect them by separating colors. Dark colors washed with light or white colored clothing can bleed colors onto the other garments. The classic scenario is turning your white clothing pink by leaving a red item in the laundry. To safely wash your clothing, separate by material such as cotton, permanent press, delicates and things that cause heavy lint.
Sorting Clothing by Color
Before washing clothes, group them by color. Whites are t-shirts, socks, underwear, linens and towels. Note that white clothing with even a small amount of color should be washed with light colored clothing. It is safe to use bleach in the washing machine when you have only whites together.
Light colored clothes are considered pale colors like blues, pinks, greens, yellows and lavender. Clothing includes solids, prints and stripes.
Dark and bright colored clothing can be saturated with dye. Washing new clothing separately a couple of times before combining garments prevents the colors from running onto other items.
Separating Clothing by Material
Delicates like bras, lingerie and sweaters made from special care fabrics need to be washed separately from other laundry. Separating cotton and permanent press clothing is helpful, since they require different washing cycles. Towels and sweatshirts leave a lot of lint behind in the clothes dryer, so wash and dry them together in the same load.
Check Pockets and Zip Up
Check pockets before placing laundry in the washing machine, otherwise you can end up washing gum, money, wallets, cell phones or ipods. It’s especially annoying when tissues or paper are left in pockets, because they shred in the washing machine and get stuck to the clothing. Zip up and close hooks on clothing to stop it from snagging on other items in the wash.
Spot the Stain and Loading the Laundry
Look for and treat stains before starting the washing machine. Use stain remover if clothing is heavily soiled. In order to get clothing clean in the wash, it needs room to move around, so don’t overload the washing machine.
Water Temperatures
Always read the label of the garment you are washing for care instructions. If a water temperature isn’t recommended, the following are generally used.
- Whites – hot water
- Lights, darks and bright colors – warm water
- Delicates – cold water
Laundry Detergent
Choose the right detergent for your washing machine. A front load washing machine needs a detergent that isn’t as sudsy as regular solutions. Other than using the right type of detergent for your washing machine, it's your preference as to what brand you use.
