Login Error
Close
Septic Tank Drain Field Repair Guide: Soil Failure
by DoItYourself Staff
A soil failure in your septic field will require drain field repair to prevent the build up of sodium that is found in many household products that end up in the septic system. A septic drain field that goes untreated for a number of years or has certain types of materials like grease and oil constantly flushed into it will eventually clog. A clogged septic tank will back up into the home and cause mess and clean up costs associated with the clean up. Read on to learn about the causes of septic tank drain soil failure, what to look for and how to prevent or reduce the possibility of the problem occurring.
Step 1: Identify Septic Drain Field Soil Failure
The septic drain field that is experiencing soil failure can present different hazards. The septic tank soil failure is usually caused by a variety of reasons which can be biological in nature or chemical in nature.
These reasons occur mainly from the improper use of the septic system, such as flushing harmful waste materials into the drain such as detergents or food products that are heavy in sodium content. The introduction of the higher than normal sodium into the soil will result in waste overflow that you and your home's residents will be exposed to.
Step 2: Stop Pouring Detergents into the Septic System
Do not address your soil failure by pouring household items and other material that will cause the soil to fail. Household items like detergents and certain food items contain sodium, which is bad for a septic drain field and system. The material leaves deposits that as they develop and accumulate over time they cause the system and the system to overflow. Avoiding chemicals will help reduce the chances of sodium and other harmful chemicals being introduced in your septic drain field.
Step 3: Establish a Maintenance Schedule
Establish a regular maintenance schedule for your septic drain field system to prevent soil failure and help keep your system working properly. The maintenance schedule should include regular cleaning of the septic tank and flushing the system in order to remove the types of chemical that can lead to soil failure.
These are some of the steps that are helpful in addressing a potential soil failure in your septic tank drain field. Regular maintenance and checking the status of your septic drain field and system periodically will help address any potential soil failure.
 forum activity
