Series of Hard-Wired Smoke Detectors: Wiring Explained
Hard wired smoke detectors are connected in a series to provide warning to every part of a home or building. Once one of the alarms goes off, the others also follow. These detectors are connected to the power source all the time to ensure maximum protection. If the power is off during a fire emergency, the detectors will still run on back up battery. Know the basics of smoke detector wiring, and learn how these detectors are connected together in a series.
Wiring Parts
The smoke detector’s wiring harness has two parts: the fixed wires on one part, and the wires that protrude from the harness. You should be able to see three wires coming out of the harness: white, black, and yellow. The black and white wires are used to connect to the power source, and the yellow wire to the other smoke detectors in a series.
To install the smoke detectors, connect a two-wire cable from the service panel to the first smoke detector. In order to connect more smoke detectors, for multilevel homes or building, use three-wire cables.
The series connection
The white wire on the detector is connected to the white wire on the service panel box. The black wire on the detector is also connected to the black wire on the service panel. The connections are to be secured using multipurpose wiring tools and further secured using electrical tape.
To connect more smoke detectors, attach the yellow wire on the smoke detector to the yellow wire on a three-wire cable. Every other smoke detector is connected to the others through the yellow wire. The black and white wires provide the smoke detectors with the power needed to sound an alarm when smoke is detected. Once a smoke detector’s wires are properly connected to the wiring on the wall or the ceiling, screw it tightly on the wall or the ceiling.
For a single smoke detector used in single level homes or apartments, the yellow wire on the smoke detector can be set aside. The black and white wires are simply connected to the black and white wires on the service panel.
However, it is recommended that houses with at least two levels should have at least one smoke alarm per level installed. This is where the yellow wire comes in. It connects all the different smoke alarms in a home or building. Once the alarm is triggered, the smoke alarm that detects the smoke also triggers the other alarms in the building to maximize protection from fire hazards.
Why install this type of detectors at home?
Hard wired smoke detectors are very important to the safety of a home or a building. Most smoke detectors usually fail because only a battery powers them. When the power on the battery discharges without any notice to the owner of the home, it poses a risk. Nowadays, hard wired smoke detectors are becoming a popular choice for homeowners and building owners alike.
