Several Countertop Resurfacing Methods
If you are dissatisfied with the appearance of your countertop, you may need to undergo a countertop resurfacing procedure in order to get it looking brand new and clean again. Whether your countertop materials have become marred by damage to the material itself in the form of chips, scratches, cuts or other related issues, or if there are stains or other signs of wear and tear, you can oftentimes repair a great deal of these problems with some simple resurfacing. Read on for a few of the most common countertop resurfacing methods.
Concrete Resurfacing
If you have a concrete based countertop, resurfacing this type of platform is one of the easier and less expensive projects that you can engage in for your kitchen remodeling project. You'll need to begin my sanding down or removing any damaged areas on the surface ofthe countertop. You can cut out large areas of the countertop if it's easier. Next, mix up a batch of the same concrete material to fill in the extra spaces in the countertop. For smaller cracks, you may wish to use concrete putty or another separate filling solution instead. Finish up by treating the surface of the countertop once again and providing any final touches that help to adjust the appearance of the concrete.
Tile Resurfacing
If you have a tile countertop that has become damaged for one reason or another, your best bet is to replace the damaged tiles with ones that are viable and new. You'll have to first remove the existing damaged tiles and then clean up the mortar that holds them in place. Set down a new layer of fresh mortar and replace those tiles with identical ones. Alternately, you can also remove all of the tile and start over, if you'd like to change the tile appearance at all.
Laminate Resurfacing
For laminate countertops, resurfacing small scratches and blemishes is relatively easy. There are laminate repair kits that you can purchase from most hardware and home improvement stores. These kits will help you to clean up any minor scratches and other damage that has occurred and get your laminate countertop looking new again. For larger amounts of damage, you may need to completely remove the laminate cover and apply it once again.
Engineered Stone and Granite Resurfacing
One of the most difficult resurfacing jobs is one that involves either engineered stone or granite material. These materials are designed to be very durable and sturdy, which is helpful because it's difficult to repair scratches and other blemishes in these surfaces. Your best bet for a clean resurfacing project that doesn't involve removing the countertop entirely is to sand down the surface layer of the counter and then refinish it with another sealant. This project can be very time consuming and difficult to get right, so many people opt to leave minor damages on their stone countertops, or to replace them entirely if the damage is severe.
