Login Error
Close
Several Methods to Remove Concrete
by DoItYourself Staff
There need to remove concrete can arise on many different occasions, whether it is due to a defect to it or undertaking a complete refurbishment. Understanding what methods can be used for the process is essential to ensure that no damage is done to the surrounding surfaces.
Jack Hammer
It is possible to rent a jack hammer from an equipment hire company to remove concrete easily. This is especially beneficial for removing a deck that has been entirely made from concrete. They can be used to break the concrete up into smaller pieces so that it is easy to remove and transport. When using a jack hammer, you should ensure that you have all the necessary safety equipment to use with it. Take into account the size, weight and vibrations of the machine to ensure that you can handle it before deciding on this option.
Crowbar
In the event that you need to remove concrete slabs, you may find that you can do so with a crowbar. As hardened concrete is not malleable and has no give, using a crowbar to pry up the edge will cause it to break or lift out of place. It is ideal for use on paving stones that have gaps between them that the crowbar can be worked into.
Chemical
There are chemicals available on the market that can be used to soften concrete to make it easier to work with. They can be applied to gaps in the concrete or holes that you have drilled to ensure that it gets deep into the concrete. These chemicals are highly toxic and should be used carefully to ensure that no harm results.
Sledgehammer
A sledgehammer can be used to remove concrete by breaking it up first. When using this method, ensure that you protect yourself from any flying particles. A shovel can be used to lift all the resulting broken pieces of concrete to make it easier to dispose of them. This method will be particularly effective on relatively thin paving slabs. Connecting the head of the hammer to strategic points, such as corners and edges, will make it easier to work on thick concrete in order to break it up.
Pick Axe
Where it is necessary to remove concrete that has been laid thickly, a pick axe can be used to create cracks in it. These can be used to break it up further by widening the width of the cracks with the use of a crowbar or screwdriver. Safety is important when using this type of tool to prevent injury being caused. If it is being hired, ensure that you follow any guidelines that you are given.
Drilling
Drilling holes deep down into the concrete can weaken the structure of it and make it easier to break it apart and remove it. Use a drill bit that is long enough to work as deep into the concrete as possible. Further, make sure that the drill bit is suitable for use on concrete.
 forum activity
