Login Error
Close
Sheathing Paper
by DoItYourself Staff
Sheathing paper is of a higher grade and of a superior quality than the standard building paper. Sheathing paper is relatively light in weight than other similar building papers. This makes sheathing paper the first choice for all do it yourself construction projects that involve some amount of relaying work.
The sheathing paper serves as a weather resistant resilient layer that regulates the inflow of moisture through the walls into the living area. The sheathing paper can also function as a unidirectional airflow regulator if it is sealed properly against any surface.
How to use Sheathing Paper Effectively in Your DIY Project
While installing sheathing paper, you have to take care to avoid any disturbance to its surface. This is because even a micro tear can decrease the effectiveness of the sheathing paper. It is better to replace the damaged sheathing paper before installation as it is very difficult to replace it once the build is complete. While buying sheathing paper, check whether its moisture vapour transmission rate meets the building regulations in your state.
 forum activity
