Login Error
Close
Shed Bulding Mistakes to Avoid
by DoItYourself Staff
Shed building can be a time-consuming and difficult process, and it is quite easy to leave out important steps or make mistakes along the way. Whether you're building a shed from scratch or following instructions for a partially assembled kit, preventing mistakes along the way will help to ensure that your shed looks good and functions well. Additionally, avoiding some of the most common construction pitfalls will protect your shed against damage and keep it fully operational for years to come.
Secure Proper Building Plans
Unless you have prior experience constructing buildings, it is likely that you'll benefit from a set of blueprints for a shed. Prepare as much as you can in advance of your construction project, and make sure that you have a complete and accurate materials list and step-by-step guide before you begin building. Your blueprints and plans should include notes about the shed from the foundation up.
If you don't have the tools and experience necessary to draft a blueprint and other plans for your shed before you begin, invest in a quality set of plans. Although many websites offer free designs and materials lists, these are generally incomplete or shoddy at best. Consult with a professional contractor or carpenter for advice about your project. Although good blueprints and professional assistance in your project may increase the overall cost of the installation, the quality of your shed and its longevity will outweigh any extra expenses that you've incurred for it.
Lay a Solid Foundation
A proper foundation is crucial to your building's stability over the long term. Without a foundation, the base of the building weakens as it is exposed to moist soil and fluctuating water levels. A solid foundation should consist of either concrete blocks or wood planks set directly into the ground. For more guidelines on how to build a proper foundation for your shed, consult with a contractor or a building professional. The extra work and expense necessary to build a foundation will save you costly damages and other expenses in the future.
Secure a Permit
Nothing is more frustrating to a builder than beginning the installation process and purchasing materials, only to discover that he isn't authorized to erect the building to his specifications because of zoning rules. Take the time and effort to research the local laws on constructing buildings on your property. It may be necessary to purchase a permit in order to build, and your shed may have to meet certain requirements. These are important considerations to take into account before you even begin the design process for your shed.
If you follow these guidelines and prepare adequately for your building procedure, you'll find that the entire construction process is an easier one. Spending the extra time and money to ensure that your building is installed correctly will pay off in the additional years of good use that you'll be able to derive from your shed.
 forum activity
