Shower Filter System Benefits
It is essential to have a shower filter system in place to lessen the exposure to chlorine and other chemicals.
Lessen Chlorine Exposure
Chlorine is used by the water department to ensure clean water supply in houses. This water gets used in the shower system. The Environmental Protection Agency (EPA) has made a statement that household have high levels of chloroform in the air, and the reason behind this is that chloroform accumulates in the air due the chlorine that is present in the water. While taking a shower or bath, chlorine gets absorbed though the skin as well as by inhalation. While taking a bath, the skin pores get widened, and this causes the chlorine to get absorbed much faster into the body.
The chlorine gas and other chemicals that are released through a shower system can have adverse effects on your health. It can cause a feeling of fatigue and loss of energy level. It can cause your skin to become dry and harsh, and skin rashes and irritations are a common side-effect. Hair becomes brittle and damaged, and respiratory problems like bronchitis and asthma can result. It can cause coughing and sore throat. Chest pain can also occur, and eyes can start watering. Fluids can build up in the lungs. Chlorine is also suspected to be the reason behind breast cancer. Cancer-ridden women are found to have more than the normal percent of chlorine in their body than healthy women.
Once you have a shower filter system in place, this will help remove chlorine and the other chemicals from the water. This in return will help prevent all the side-effects caused by the chemicals. The air quality in the house will improve, and your skin will have a healthier glow and your hair will become softer and shinier.
