cancel
Job type :
Zip Code :
community forums
comments
Silk Rug Cleaning Do's and Don'ts
Although silk is can be a strong rug fiber, silk rug cleaning should be approached carefully. Silk rugs are expensive and easily damaged by improper silk rug cleaning.
Do: Treat Stains as Soon as They Occur
Stains treated immediately are less likely to leave a long term stain on the rug. Remove any solid parts of the stain, then gently blot out the liquid. Club soda can also help to release the stain. Allow the rug to air-dry after cleaning.
Do: Choose a Blend of Silk and Wool Whenever Possible
Wool blended with silk will maintain the beauty and softness of a silk rug, but is more likely to repel stains. Choose a wool-silk blend whenever possible.
Do: Have the Silk Rug Cleaned by a Professional Whenever Possible
Have your silk rug cleaned by a professional cleaner. This will ensure that your silk rug receives the best treatment.
Don't: Place Silk Rugs in High Traffic Area
Rugs in high-traffic areas are more likely to be stained or to wear out. To give your rug a long lifespan, place the rug in a low-traffic area.
Don't: Clean Silk Rugs with Hot Water or Strong Chemicals
Hot water will permanently damage silk rugs, so do not use water above a lukewarm temperature. The strongest chemical you should use on your silk rug is a solution of water and white vinegar; stronger chemicals can damage the rug.
member comments
Did-it-myself Projects
updated by Ididit
did this on 5/15/2008
Painting
updated by dooplesandpal
did this on 4/25/2008
New Dining Room
updated by Liggens
did this on 2/24/2008
Restore
Your Winter Home Checklist
sponsored articles of the day
