Simple Quonset Hut Construction Tips
A Quonset hut is a simple structure that can be used for a variety of applications. You see them used as hangars, barns, warehouses, storage facilities, and even retail shops and offices. They offer an inexpensive alternative to traditional design and can be put up in much less time. Here are a few things to keep in mind when constructing your own Quonset hut.
Type of Hut Needed?
Before you start to break ground on a Quonset hut, you need to think about what you will be using it for. You will have a few options for the hut itself. You can choose a full arch or a ‘mailbox’ style. The full arch has a semi-circle and will usually hold more weight. The full arch styles tend to be more pleasing to the eye for most people as well.
Location is Important
You want to check your local zoning laws and make sure you are even allowed to place a Quonset structure on your property. A barn may require different permits than a retail shop. Residences require even more permits, and there may be restrictions regarding where you can place these structures. There is no point in ordering a kit and spending valuable money just to discover that you won’t be able to place it.
How Easy is it to Construct?
A Quonset hut is much simpler to put together than a traditional building. This is one of the key reasons they are so popular, even today. You can generally order kits online and from reputable builders that will include all the steel you will need. You can even customize the size and other options associated with them. They can be constructed in a few weeks and only require a handful of people, as opposed to several months and a full construction crew.
Foundations
You will need to place a foundation for you Quonset hut. If you’re using the hut as a barn or storage shed then you may be able to get away without having a foundation. It’s still usually a good idea to at least place wood down as a foundation. If you expect to spend any amount of time in the hut you may want to lay concrete to serve as a floor. Walking on a bare ground floor can be offsetting to many people.
Exterior Priming
After the structure has been constructed, you may want to prime the exterior so that it’s weatherproof. You can find a high quality silicone sealant placed between the panels will work very well to weatherproof the Quonset hut. You can also apply a primer paint to the outside to further the weatherproofing. This will help to give you may more years of use out of your hut.
Interior Space
When you have constructed your Quonset hut you can begin working on the interior. You can hang traditional walls in side just as in any structure. Wood paneling can be used as well if you are looking for a more expensive way to finish it off.
