Single Pane vs Double Pane Windows
Double pane windows offer a green solution to increase the energy efficiency in your home. Older homes and even some newer models have single pane windows, although double pane windows are an increasingly popular choice. If you are replacing the windows on your home, consider the differences between the two styles before deciding.
Single vs. Double Pane Windows
The primary advantage of single pane windows is the cost. The amount of material that goes into them and the manufacturing process is much less than that of double pane windows. Glass technology is much more advanced that it was a century ago, so even though single pane windows are not the most energy efficient, you can expect them to be of a high quality.
On the other hand, double pane windows provide by far a greater amount of insulation from the outside. Because they contain two panes of glass with a sealed barrier of air between them, they keep cold air out and warm air in. Thus, they are much more efficient in terms of energy saving. The downside is that they are much more expensive than single pane windows. However, by installing them in your home, you may be eligible for a tax credit for increasing the energy efficiency and cutting your costs. Although they are more expensive, they will save you more money in the long run.
Both single and double pane windows are available to install in your home. They are both of high quality, but double pane windows are far superior in terms of energy conservation. Even though they cost more, they are the better choice.
