Sink Slow Drain: What To Use for a Partial Clog
If you are witnessing a slow drain sink early in the morning as the whole family awaits their turn for the bathroom, read on. Bathroom sinks tend to get partially clogged over time. It can be due to particles in water that get accumulated in the drain, toothpaste, gel, and other products that harden over time. There are a few easy techniques you can apply to save you from the daily morning blues.
Hot Water
The first thing you should try in the case of a partially clogged drain is to pour hot water into it. Filling the sink up with hot water first and then letting the water slowly sink can help unclog a sink slow drain.
Manual Cleaning
If hot water does not seem to solve the problem of the slow sink drain, you will have to remove the drain cover for a close look. Look for any items or particles that may be visibly partially blocking the drain. Hair can accumulate in drains over time. If you spot hair, remove the hair using appropriate tools.
Drain Cleaning Products
