Login Error
Close
Six Advantages of Using a UV Water Filter
by DoItYourself Staff
A UV water filter is easy to use and offers an excellent level of protection against germs and bacteria. Using ultraviolet waves to kill germs and bacteria is a superior method of purification of any water type from any type of harmful bacteria. To be scientifically accurate a UV water filter doesn’t really destroy bacteria but it makes it inactive, that is, not dangerous. There are a number of reasons why you should use a UV water filter.
1. Composition of Water
By using UV water filters you can be certain to eliminate all possible threats and leave the composition of water intact. The composition of water is easily altered when you add chemicals, such as chlorine. This disrupts the harmonious composition of water which can create some undesired effects. Water can also be altered by using heat, but by making use of a UV water filter this situation can be easily avoided. This method will avoid the possibility of harmful disinfection by-products produced by filtering chemicals.
2. Time Needed To Disinfect the Water
With the help of a UV water filter, the disinfection can be done in a shorter time. Other chemical methods may require many hours or even a whole day for the chemicals to settle and start to disinfect water. This is not the case in UV water filters because disinfection can be done easily and quickly.
3. The Best Disease-Free Solution
Much sickness is caused by water bacteria, such as, tuberculosis, meningitis, cholera etc. This can be avoided by using a UV water filter to inactivate all of the bacteria in your water system. Other methods, still don’t eliminate effectively the above mentioned diseases but this isn’t the case if you use a UV water filter. This is a major advantage when using a UV water filter; it reduces health risks.
4. Purchase Price and Maintenance Cost
A UV water filter doesn’t cost too much compared to its beneficial results. Also an important thing is that a UV water filter is very cheap to maintain thus it is the ideal equipment to use as a filter system.
5. Environmentally Friendly and Ideal For Long-Term Use
The filtering process used by a UV water filter is very natural hence it is environmentally friendly and can be used anywhere in the home. For this reason it is also considered ideal for emergency situations where the source of water is questionable thus you may need to disinfect it properly.
6. Can Be Used Simultaneously With Other Filters
In the eventuality that you may need more than one method of filtering in your home, you can be rest assured that a UV water filter can be used simultaneously with other methods. In normal circumstances you would only need the UV water filter, but a situation may arise that requires that you further disinfect your water or you wish to keep your already installed filters and add on to them.
As you can see UV water filters have many advantages and it would be a good idea that every family has one. If not used regularly, it can come in handy in an emergency.
 forum activity
