Login Error
Close
Six Modern Paint Color Schemes for Wood Paneling
by DoItYourself Staff
Wood paneling is often much more appreciated than other wall panels which are usually made from laminated materials. Even though wood panels are a little more expensive, they still are the preferred choice of a lot of people since they can provide a glimpse of wood's natural beauty, enhancing any room. The following are just some of the most common wood paneling colors which can match the present demand of modern interior decor.
1. Gray Oak
One of the most demanded colors in modern interiors is gray. This color, midway between white and black can match a large variety of white and cream interior decorations which are also common with modern rooms. Gray oak is generally used in livingrooms and in bathrooms and since it is a rather dark color, it requires a lot of lighting to balance the room environment.
2. Ebony Macassar Wood
Another high demanded dark hue in modern interiors is ebony macassar wood. This wood is a slightly different from ebony wood and it provides a much more exotic look. Moreover, macassar wood panels are very common in offices and libraries since they combine perfectly with office furniture. Once again this wood color needs a lot of lighting and a gloss lacquer finish will magnificently enhance these wood panels.
3. Rose Oak
A modern light color for wood paneling is rose oak. This color combines perfectly with other light color decorations such as purple or turquoise. In addition, this color is commonly found in bedrooms and not so much in bathrooms or kitchens.
4. Zebrawood
This material is rather an exotic one. Zebrawood, as the name implies, is a type of wood which has a beautiful texture simulating zebra skin. This stylish wood is also common in offices and libraries and it can easily be cleaned with a non-abrasive detergent. It can also be found in tile size and hence, you can create a modern texture with these wood panels.
5. Safari Black Wood
Black is certainly the most frequently used color in modern interiors. Although a bit strange, safari black wood panels can light up a room since they balance the amount of light in it and at the same time create a unique and warm atmosphere. Black wood panels are being used in every room of our homes even in kitchens and in bathrooms. In addition, black wood can match a vast variety of colors and so, it satisfies the taste of a lot of people.
6. Dark Walnut
Dark walnut has always been one of the favorite wood colors for centuries. Even today, this dark color is also very common in modern interiors for its dark but pleasant look. It is used in bathrooms and living rooms but it can also be used in kitchens if the room is well lit or combined with enough lighting. Dark walnut paneling is also used in upscale restaurants to create a romantic, luxurious atmosphere.
These color schemes are just some of the wide range of colors for modern interiors. In the end, whatever type or color of wood paneling you choose, your imagination is the key to creating the desired atmosphere in your home.
 forum activity
