Six Tips for Mold and Mildew Control
A common problem that you may run into as a homeowners is mold and mildew control. This moist organic matter can be a source of potential health problems for all members of the household. Nevertheless, by following these tips you can help keeping your home clean and healthy.
1. Locate the Mold and Mildew Growth
The first step to eliminating mold and mildew is by locating the spots where they can grow. Think about areas that have high humidity levels such as bathrooms, basements and kitchens. Even leaky pipes can promote mold and mildew growth and it can spread to any exposed wood or wallboard. These porous materials or others like carpets or insulation should be removed, discarded and replaced immediately.
2. Non Porous Materials
Non porous materials like those found in your bathroom can be easily cleaned. Your bathtub and sink are probably the most common areas of the bathroom for mold and mildew. Thus, there are many disinfectants and cleaners that help eliminate mold and mildew. However, if you are using bleach never combine it with any products that contain ammonia since this will result in the release of a dangerous toxic gas.
3. Protect Yourself
The most important part of the process is to protect yourself and your family. Since mold and mildew can cause various illnesses, always wear rubber gloves and a mask when cleaning it and it is a good idea to keep the effected area well-ventilated.
4. Using Bleach
An effective solution to help remove mold and mildew is a mixture of ¾ cup bleach with a gallon of water. When cleaning a shower take down the curtain and then work from the top of the shower walls down to the drain. To clean the bathtub, start by first cleaning the faucets with the same solution and then clean the handles and the tub basement. Use also a drain cleaning product to clean the drains of both the shower and bathtub.
5. Working on Tiles
To help remove mold and mildew from tiles, fill a new spray bottle with the bleach solution and spray the whole area. Let the solution stand for about 10 minutes and rinse with clean hot water. Use the same procedure to clean the grouts but instead scrub the solution into the grouts with a brush. If the tile sealant contains mold and mildew, it should also be replaced. Use a putty knife to remove the old sealant and clean the joints with the bleach solution. Then use a sealant which contains an antimicrobial to resist the future growth of mold and germs.
6. Exhaust Fan
If you have an exhaust fan make sure to use it every time you take a shower. This fan is essential for removing moisture from the air, which is important in maintaining a mold-resistant home. Use also a mold resistant liner to hang the shower’s curtain.
Now that you know how to reduce mold and mildew in your bathroom, apply the same cleaning methods to other areas of your home. Just remember that non porous materials can be rescued with a little cleaning and disinfectant but porous materials need to be replaced. However, if a large area of your home has been effected, do not attempt to clean it yourself. Contact a professional.
