Login Error
Close
Slate Tile Flooring vs Ceramic Tile Flooring
by DoItYourself Staff
Two popular flooring options are slate tile flooring and ceramic tile flooring. Both are decorative and satisfy basic flooring needs, but there are pros and cons for each. If you are trying to decide between slate tile and ceramic tile for your next flooring project, consider these important factors.
Slate Tile Flooring
Slate is a natural stone, which is extremely durable and long-lasting floor surface. It has a high resistance to chipping and cracking as well. Unlike other natural stone tiles, slate tiles resist damage from acidic substances such as soda, tea and wine. In this respect, it is similar to ceramic tile. A major consideration when installing slate tile flooring is weight. Slate is heavy, so if you are handling your own installation, keep this in mind. Slate is valued for its natural beauty and, therefore, is more expensive than ceramic tile.
Ceramic tile flooring is the most common tile flooring available. This is due to its low price and extensive design variety. Because it is man-made, ceramic tile is much less expensive than slate tile. Unfortunately, ceramic tile does not have the natural beauty of slate tile, but it does come in an almost infinite variety of colors, patterns and textures. Ceramic tile is also the best flooring option if you plan to install radiant floor heating because of its ability to conduct and store heat.
Whether you choose slate tile flooring or ceramic tile flooring, your design options are extensive.
 forum activity
