cancel
Job type :
Zip Code :
community forums
comments
Sleek Motorized Ceiling Mount Styles
Having a motorized ceiling mount is a great addition to any home. They offer ease of use, affordability, and space saving designs. Here are a few options.
Back Plates
These are the most popular style. They fit directly behind the television and are virtually unseen once installed. A back plate motorized mount will generally give you full tilt capability, as well as a large swivel area. These are designed for smaller televisions, usually under 40 inches.
Encased
For larger televisions, you may want to consider an encasement. Instead of fitting directly on the back of the television, these have arms and bars that hug the television snugly in place around the frame. They offer all the advantages of a back plate with full range of motion, but they give you added security for your heavier television.
Retractable
The retractable mounts are growing more popular. They are available for both large and small televisions, are virtually invisible behind the television, and offer full range of motion. The unique part of this type of mount is the ability to extend outwards toward the center of the room. The mount has a motorized arm that resembles an accordion, giving you even more options with viewing.
member comments
Related Articles
What Can be WiredWhat Can be Wired
What can be wired in your home... read more
Hooking Up Your HDTVHooking Up Your HDTV
Overwhelmed by the number of multi-colored ports on your new television? This guide explains which... read more
X10 Home Automation Q and A - Part # 3X10 Home Automation Q and A - Part # 3
X10Home Automation Components and Wiring... read more
articles we like
Painting Countertops
Painting countertops has become a popular alternative to replacing laminate countertops, so let’s look at... read more
Type 2 Diabetes
Type 2 diabetes commonly affects people between the age of forty and forty five. The... read more
Fix, Edit and Enhance Your Text in One ClickFix, Edit and Enhance Your Text in One Click
Spelling and grammar mistakes can often be laughed off when the communications are between friends,... read more
sponsored articles of the day
diy centers
