Login Error
Close
Small Bathroom Remodeling Ideas
by DoItYourself Staff
The bathroom is considered to be one of the busiest rooms of the house and sometimes needs remodeling, but there are some small bathroom remodeling ideas that you can do yourself. These renovations are not expensive and they give a better look to your bathroom. You can use certain strategies that make the bathroom look larger than its actual size.
Installing Grab Bars
This idea of equipping your bathroom with grab bars is more useful for the future rather than for the present. They come in really handy if you have sick or injured people living with you in the house, or in case you get injured yourself.
Grab bars are a very helpful addition to the bathroom area; they can be fixed to the toilet and bath areas or even in the hallways that lead to them. They can prevent accidents as well as provide help to those people who struggle with mobility.
Fixing a Floating Vanity
Floating vanities are a must for modern bathrooms, especially when space is an issue. They take up much less space than an ordinary vanity unit, but at the same time do not compromise the overall style of your room. On the contrary, its clean-cut edges and simple modern lines enhance the feeling of space.
Covering the Walls with Glossy Tiles
Glossy tiles reflect light back into the room and therefore help to give the impression of a well-lit room and more space. You can replace the old tiles with new glossy ones. Another advantage of glossy tiles is that they do not get dirty easily.
Distinguishing and Selecting Fixtures
The bathroom is equipped with a long list of fixtures; the most common ones are those which you find in the sink, the shower and the bath. Substituting your present ones with leaner, more modern styles will improve your room's appearance.
You can also install LED lights in the water outlets of your bath or shower to give it a more modern look. These lights change color according to the water's temperature. The light turns blue if the water is cold and then it turns red when the water is hot. This bathroom remodeling idea is helpful for young children and people who have poor eyesight or vision problems.
Painting the Bathroom
This may not be a number one favorite task to go through, but it certainly is a number one option which will instantly transform your room. Giving a new coat of paint to the walls of the bathroom revives and brightens its atmosphere. You can choose to paint your bathroom with any color you like. Painting your bathroom can be considered a small project that makes a great difference.
Installing a Shower Screen
A shower screen gives you all the privacy needed as you are showering, even though they still allow light to enter the shower area. There are many types of shower screens. Most of them are made of glass, and you can select etched, stained or frosted glass.
These are just a few and the most common bathroom remodeling ideas available. You can opt to go through more complex changes which may require more money and which are more time consuming.
 forum activity
