cancel
Job type :
Zip Code :
community forums
comments
Features of Small Dehumidifiers
Small dehumidifiers as they are called are the larger version of the mini dehumidifiers. The small dehumidifiers are meant to work in larger rooms than the mini dehumidifiers. They work though, the same way as the minis and have packets or salt or silica gel that absorbs up to sixteen ounces of moisture. When the silica gel or the salt wears out it is possible to install a new one, but the cost of replacing is almost the same as replacing the small dehumidifiers, for they are very inexpensive.
Main features of Small Dehumidifiers
• The silica gel or salt needs no power to activate absorption.
• The gadgets are very light and compact despite performing huge tasks.
• Small dehumidifiers are relatively inexpensive and easy to maintain compared to other larger ones as portable humidifiers.
• They are rechargeable, thus no constant plugging in is required, especially when renewing.
• Uses the water glass technology that attracts moisture from the atmosphere.
• Are user friendly, hence can be used by anyone at any place.
The advantages brought about by the small dehumidifiers are awesome as they eliminate the growth of molds, mildew and moisture rot of our properties.
member comments
Did-it-myself Projects
updated by FelipeBR
did this on 9/22/2009
Iphone Bus Holder
updated by SolarPanel
did this on 8/29/2009
Home Build Solar System
updated by dorfin
did this on 3/30/2009
Recoil Starter Repair
Painting Stylish Wall Borders
sponsored articles of the day
