Login Error
Close
Small Engine Carburetor Cleaning And Maintenance Tips
by DoItYourself Staff
A small engine carburetor is one of the most important small engine parts. It mixes fuel and air together. This mixture is necessary for the engine to function. Carburetors, especially those found on small engines, are relatively simple devices but they do require periodic maintenance to ensure they function properly.
Causes of Carburetor Problems
The biggest cause of carburetor problems occurs as a result of fuel evaporating in the carburetor. Over time this leads to a gum-like substance which prevents the carburetor from operating properly or at all. The most common problem occurs when the needle becomes stuck. When this occurs the fuel is no longer able to flow. Problems can also occur if dirt or debris gets into the carburetor through the air intake.
Preventing These Problems
  • Remove gas from the carburetor. This is especially important if the engine will be sitting for a while. To remove gas from the carburetor simply turn off the fuel line valve and allow the engine to keep running until it dies naturally. By doing this you are allowing the engine to burn the fuel remaining in the carburetor. It is also a good idea, especially for long periods of storage, to remove all fuel from the fuel tank.
  • Replace the air filter periodically. Every time you change the oil you should inspect the air filter. If it looks dirty and worn, replace it with a new filter. This will not only ensure better operation of the engine but it will also help prevent particles of dirt and other debris from getting into the carburetor. Never run the engine without an air filter.
10 Steps for Cleaning a Dirty Carburetor
  1. Turn off the fuel valve.
  2. Remove the carburetor completely from the engine. The steps to do this vary depending on the engine design and model but typically you will need to remove the air filter panel and disconnect the governor and fuel line from the carburetor.
  3. Open the carburetor up. Most small engine carburetors have a nut or a screw at the bottom of the carburetor bowl. Holding the carburetor over a bucket, remove the screw and take the bowl off.  Allow the left over fuel to drain into the bucket.
  4. Pay close attention to the layout of the interior of the carburetor.
  5. Inspect the needle to determine if it is stuck or sticking. The needle should move easily and smoothly. The needle is a small bullet-shaped device. The needle will be made out of plastic although it may also have some aluminum covering it.
  6. If the needle appears to be stuck then it will need to be cleaned. Remove it and clean it using a wire brush and either carburetor cleaner or brake cleaner. Place it back in and test it.
  7. Spray carburetor cleaner or break cleaner into all the fuel lines throughout the carburetor. Inspect them for any buildup which may block proper flow.
  8. If you have a carburetor test, use it to test the carburetor.
  9. Reassemble the carburetor and attach it to the engine.
  10. Test the engine to determine if it is functioning properly. Remember, the carburetor will be fully drained so it may take several seconds for the bowl to fill up with fuel.
 forum activity
