cancel
Job type :
Zip Code :
community forums
comments
Small Engine Start Up for Lawnmowers, Trimmers, Snowblowers, and Leaf blowers
By Murray Anderson
Is it time to put away your snow blower? Want to make sure the engine will start next fall when you need it? Small engines that are just put away once their season is over (snow blowers, lawn mowers), can be cranky and hard to start next season. Six months after you just left them in the garage or shed is not the time to think about what you could have done. Making sure that engine will start next season isn't hard and it'll probably take you less than an hour. Come next season I know you'll agree it was time well spent here’s all you have to do to make sure that engine starts.
Here's what you need
  • Motor oil
  • Oil can
  • Spark plug or adjustable wrench
  • Funnel
  • Gasoline storage can
  • Detergent and clean water
Start by Draining the Oil
If the engine hasn't been running for a while, start it and let it warm up. Once its warm shut it off and drain the oil from the crankcase. It's best to do this while the engine is still warm so impurities tiny particles in suspension in the oil will drain right out. Now, refill the engine with fresh oil - probably 10W30 but be sure to use whatever your owner's manual specifies.
Note: You only need to drain the oil in 4 cycle engines, (motor runs on straight gasoline). 2 cycle engines (where the oil and gasoline are mixed before use) don’t have a crankcase, and the oil and gasoline mixture together lubricates the engine.
Clean the Air Filter
Most small engines have a plastic foam air filter that is impregnated with oil to catch dust. Over time the filter gets plugged with dust and stops filtering. Take out the air filter and clean it in by washing it in warm water and dish detergent. Dry it by wrapping it in a paper towel and squeezing it, then re coat it with clean oil and replace it.
Drain the Gas Tank
Once the engine is cool, you want to drain the gas tank. There's usually a small rubber hose attached to the bottom of the tank held in place by a pressure clip. Use a funnel and drain the gasoline into a tin can or gas storage can. Once the tank is empty, start the engine and let it run on the gas remaining in the carburetor until the engine stops, out of fuel. By running the engine out of fuel, you eliminate the chance that the gas in your carburetor and fuel system will evaporate and "varnish" over time. A carburetor with gas residue (varnish) in it won’t work properly and you'll likely need to remove and clean it for your engine to run properly next season.
An alternative to running your engine out of fuel is to fill the tank right up with gas and add a "gasoline stabilizer" (available at home and automotive stores), that's formulated to stop gas from varnishing and plugging your fuel system. The downside to this approach is you need to store your engine with a full tank of fuel and by next season; the gas will be six months old.
Remove the Spark Plug
Use a spark plug wrench or if you don't have one, as adjustable wrench to remove the spark plug. Apply slow easy pressure, don't jerk on it, and remember, spark plugs can break.
Once the plug is out of the engine, use an oil can to put a few squirts of oil right into the spark plug hole. Now, without replacing the plug, pull slowly on the starter cord to turn the engine over a few times. This will spread the oil you just squirted in onto valves preventing any rust from building up inside the motor.
While you've got the plug in your hand, check the tip. If it’s pitted or corroded you should replace it, but if it's just dirty, you can clean the gap and put it back into the engine - hand tight. If you decide to replace the spark plug take the old one with you to the store to make sure you get an exact replacement - all spark plugs aren't the same.
That's it. All that’s left to do is store your snow blower/lawn mower away from weather and animals for the season Come next year, tighten the spark plug, fill the tank with fresh gasoline and start it up. Don't be alarmed if the oil you squirted into the cylinder head makes the exhaust smoky for a few minutes until it's burned up.
Isn't it nice to have an engine that starts when you need it?
Murray Anderson is an experienced freelance writer. His work has covered a wide range of topics, but he specializes in home maintenance and how to's. He has more than 500 articles published on the web, as well as print magazines and newspapers in both the United States and Canada.
member comments
Related Articles
How to Estimate Lawn Care Costs
Estimating lawn care costs is essential regardless of whether you are planning to simply maintain... read more
Answers to Lawn Care Questions #2
Answers To Your Gardening Question... read more
How to Grow a Lawn that's Lush, Green and Thick
A guide to techniques for keeping your lawn looking thick and healthy, from weeding and... read more
articles we like
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Transom Window
A transom window is a common feature in modern homes. The window rests over the... read more
Active duty servicemen get degrees, come home to great careersActive duty servicemen get degrees, come home to great careers
Joining the military used to mean postponing a college education. Now, however, thanks to online... read more
sponsored articles of the day
diy centers
