Login Error
Close
Small Pellet Stove Room Heating
by DoItYourself Staff
If you’re looking for an alternative room heating measure to shift away from the conventional wood stoves, a highly recommended option are small pellet stove room heating devices that have become all the rage around the world. The attraction underlying the popularity of the small pellet stove as a room heating device stems from its economical, efficient and environmentally friendly nature.
How do Pellet Stoves Work?
Pellet stoves work using fuel pellets made up of organic and biodegradable materials such as sawdust, wooden shavings, bark pieces, waste food pieces, agricultural byproducts and chips of wood and corn kernels and so on. These fuel pellets are stored in the fuel hopper until they are to be used. From the fuel hopper the pellets are dropped into the combustion chamber via the feeder. The combustion chamber is where the pellets burn in order to produce the heat. A flue pipe acts as the exhaust to direct the fumes away from the room and out of the house either through an external pipe in the wall or via a chimney and out through the roof. A small pellet stove is an ideal device for warming up a room during the winter months for a cozy and comfortable atmosphere.
What are the Benefits of Using a Small Pellet Stove in the House?
The popularity of the pellet stove as a home warming device stems from the number of benefits it offers to its users. Ranging from efficiency benefits to safety advantages, from environmental benefits to cost effectiveness, the small pellet stove is no doubt the ideal heating appliance for in-home use. Some of the advantages that come with using the pellet stove are:
  • Pellet stoves come in 2 forms: as individual units or as fireplace attachments. Depending upon the need for heating, the area to be covered as well as space constraints, the options range from a stand alone device to a stove which can be fitted into the fireplace to optimize the space without having to compromise on all the benefits of the stove.
  • Pellet stoves offer an enviable degree of convenience to the users. The pellets do not have to be prepared in order to be used, as is the case with wood which needs to be chopped when it comes to conventional wooden stoves. Hence, all one really need to do is purchase the pellets and put them into the hopper and the stove is ready to go.
  • Pellet stoves are extremely environmentally friendly because they make use of organic materials and biodegradable materials. The matter that is used in making these pellets is generally waste produce which is not harmful in nature, but would have otherwise been dumped. Instead of cutting wood specifically for heating purposes, these pellets provide an alternative way to recycle waste products. These pellets don’t contain any chemicals and are hence safe to burn.
  • Pellet stoves do not give off as much smoke as wood blocks and the residue is also much easier to dispose off.
 forum activity
