Login Error
Close
Soffit Vent Installation Tips
by DoItYourself Staff
A soffit vent that is installed in a kitchen range hood plays an important role in maintaining a healthy and comfortable home. Typically, soffit vents are installed under the eaves of the house. You can choose from perforated, continuous, and circular vents, and also, you can get them in plastic or aluminum. Here are some tips for installing a soffit vent for your kitchen range hood and some common mistakes to avoid.
Venting Option
For kitchen range hoods, you can vent through the roof or the wall. Often, poor choice of installation results in more damage than good. Consult a professional, or even a salesperson at the hardware store, to help you choose the right venting option.
Preliminary Checks
Get a professional to check whether your house is structurally sound for installation. Also, check with the local authorities if you need any permits prior to installation.
Secure the Vent
When installing soffit vents, you need to secure it tightly to avoid any mishaps. Secure the vent in place using screws.
Use Safety Gear
Always wear gloves, safety goggles, and a dust mask when installing a soffit vent. You should also keep a first-aid kit handy.
 forum activity
