Login Error
Close
Soft Close Toilet Seat Benefits
by DoItYourself Staff
A soft close toilet seat is a very quiet, easy-to-install alternative to traditional toilet seats. As the name implies, these unique bathroom fixtures are designed to close in a very slow fashion and won't come crashing down should you lose your grip on them.  Below are some of the best reasons to make a soft close toilet seat a permanent part of your bathroom.
Makes Very Little Noise
Unlike traditional toilet seats, which make unpleasant pounding sounds whenever they're closed too forcefully, a soft close seat makes virtually no sound at all, regardless of how much pressure is applied when closing it. The lack of loud noise produced by these seats is particularly helpful if anyone in your home has a propensity for losing their grip when closing toilet seats. Small children, in particular, have problems when it comes to properly closing seats.
If you or any of your family members frequently get up to use the bathroom in the middle of the night, you needn't worry about waking anyone when opening and closing a soft close toilet seat. This is very useful in homes with small children or elderly adults who consistently have to use the bathroom at various points throughout the night. Additionally, if you often abstain from making middle-of-the-night bathroom visits for fear of waking your family, a soft close seat will offer you some long overdue relief.
Helps Protect Your Toilet Bowl
In addition to creating unpleasant noises, traditional toilet seats can cause considerable damage to your toilet bowl when consistently closed with a substantial amount of force. To that end, it's worth noting that most cracked toilets bowls cannot be repaired and will almost always need to be replaced. As any homeowner knows, toilets can be very expensive, so when choosing a toilet seat, remember to take the well being of your toilet bowl into account before making your selection.
Resistant to Mold and Mildew
Most soft close toilet seats are composed of high end bacteria-resistant plastic and vinyl. In addition to making them comfortable to sit on, this makes soft close seats less prone to mold and mildew infestation than regular toilet seats, which, in turn, means they don't need to be cleaned as often. Whereas traditional seats should be cleaned once a week, you can probably get by with cleaning soft close seats on a biweekly basis. So if you're already bogged down with housework, soft close seats can offer you some much needed respite.
Easy to Install
Lest you think installation is a hassle, most soft close toilet seats can be installed with nothing more than a flat-head screwdriver and a few plastic screws. Even for the most inexperienced handyman, screwing a soft close seat onto a toilet bowl should take no more than 15 minutes. Furthermore, soft close seats are very easy to remove, so if you ever want to replace them or simply remove them for cleaning purposes, a flat-head screwdriver is the only tool you'll need.
 forum activity
