Login Error
Close
Solar Battery Charger Basics
by DoItYourself Staff
Solar battery chargers are one of the current methods environmentally conscious people can use to protect the environment and add convenience to their own lives. As the technology improves, solar battery chargers are gaining popularity.
By using a solar battery charger, you can extend the life of your batteries. As the world’s fossil fuel supplies run low, any steps individual consumers take to decrease their dependence on those fuels helps the energy supply. Investing in a solar powered battery charger is an excellent place to start.
Types of Solar Chargers
There are many different types of solar chargers from which to choose. One type is a solar panel battery charger. These are primarily used to power small batteries for things such as computer batteries. These particular chargers come in several voltage packages, the most popular being 12 volts.
The solar panel chargers are also made to recharge batteries used in marine or outdoor equipment environments, which can save you from ever having to plug these batteries into a socket to recharge them. These solar chargers cost under $100, generally speaking.
You can also find solar powered battery chargers that will charge rechargeable alkaline batteries. Use care when leaving your batteries out in the sun for long periods of time, as too much exposure to sun can cause the batteries to leak.
You can even buy solar cell phone chargers. They are inexpensive and reliable. Most of these solar chargers come with only one solar cell and have attachment to fit any make or model cellular phone. With the ubiquity of cellular phones, solar cell phone chargers could have a significant positive impact on the environment if many people began using them.
Research Before You Buy
Although choosing the right solar battery charger can be a tedious process, the effort is worthwhile. You may want to consult a specialist before making your purchase. If you do not have time for consultations, the next best choice for doing your research is looking for user reviews. You will be able to find trends that can make your choice easier.
Research is your best friend when considering which solar battery power chargers you may need for your electronics. Find out what products are used successfully by others and what problems they have encountered with solar batter chargers.
Why Use Solar?
The most obvious benefit is using renewable power generated from the sun instead of fossil fuels. Saving money is always appreciated as well, and solar chargers can save you money.
 forum activity
