Login Error
Close
Solar Home Lighting Installation: A Brighter Future Awaits
by DoItYourself Staff
The idea of installing solar home lighting may sound like a bit of a headache, but it is not as hard as you may think. You can go about it several ways. You can purchase lights that you can install yourself, or you can hire a contractor to do the work for you. Choosing to use solar powered lighting can pave the way to other “green” changes for you in the future.
Installing the Solar Lights Yourself
You can purchase solar lights at any department store or home improvement store. Most of them work by running a cord from the light fixture to a solar panel outside. It is relatively easy to replace every light in your home with these fixtures. They range in size and affordability. You can purchase anything from a simple solar powered desk lamp to a large light fixture for the ceiling in your living room.
The smaller lamps are cheaper obviously, but the larger light fixture can provide much more light. It will cost more for the light fixtures, but you will enjoy the next electric bill like never before! The satisfaction of knowing that you did it yourself is also an added benefit.
Company Solar Installation
When choosing a company you will always want to price compare and check any possible reviews that their clients may have posted. Many companies will offer packages that could even include powering other items with solar panels. Make sure you check for any installation deals by looking into these companies thoroughly. Choosing a company to install your solar lights can be expensive, so try to save money where you can. It will cost quite a bit more to hire a company or contractor to convert your lighting needs from using electricity to using solar power, but again the benefits are well worth the upfront cost.
Benefits of Solar Home Lighting
With our fuel sources quickly dwindling, you will be prepared for the backlash when fuel starts to run dry. You can assure your family will have lights even when your local power plant is offline. The most talked about benefit for a consumer would be the savings that are a direct result of using anything that is solar powered. You will notice a significant decrease in your electric bill if you convert your entire home from fuel burning electricity to sun powered electricity.
The product itself may cost you a pretty penny, but the methods of powering it is absolutely free. The sun shines every day, and some solar powered lights will still continue to charge even with cloud cover.
 forum activity
