Login Error
Close
Soldering Gun vs Soldering Iron
by DoItYourself Staff
If you’re wondering what tool to use for jointing jobs, a soldering gun will do well. It is used for soldering various metal surfaces. This pistol-shaped tool has a trigger that enables you to conveniently operate with one hand. Also useful in jointing operations is a soldering iron. It utilizes a heated metal tip for soldering jobs. Although the two tools perform the same function, there are advantages and disadvantages to each.
Advantages of Soldering Guns
They have higher power voltage than soldering irons. This typically ranges from 100 to 240 watts. The solder gun gives you more flexibility while working. It has a uniquely shaped tip in the form of a loop of copper wire. This allows you to work in confined spaces. It is not easy to accomplish this with a soldering iron. The solder gun can be used for heavy electrical connections as well as lighter metal work. It heats up faster than the iron. A special step-down transformer converts power from the mains to low voltage yet high amperage current. This enables the heating element to heat up quickly. Within seconds of turning it on, the tip is ready to solder. Due to the instant heat-up and cool-down effect, a solder gun is more economical in electric power usage. The solder gun incorporates a small light that is activated once you depress the trigger. This enhances visibility which enables a more satisfactory job outcome.
Disadvantages
During soldering, the copper wire loop gradually dissolves. It must be regularly replaced, which adds to overall time taken to complete a job. The gun is heavier than the soldering iron. This can cause physical strain during work. It may also detract from how effectively you are able to work. For smaller work pieces, the bulky nature of the solder gun may cause clumsiness. Solder guns are better suited for intermittent use due to the way the transformer operates. This is likely to disrupt the flow of your work.
Advantages of Soldering Iron
It is a lighter tool than the solder gun, which makes it easier to work with. The solder iron is a versatile tool. It is available in a wide range of sizes which gives you more flexibility. The smaller irons are better suited for light electronics work. Larger irons can be used for heavy jobs. Most solder irons have a wide range of tips. This allows you to undertake various tasks. It adds to the efficiency of the solder iron. Since the solder iron remains hot for longer, you needn’t keep turning it on and off. This allows you to have a smoother work flow. It can make all the difference in getting a job completed faster.
Disadvantages
If you have heavy work pieces, you’ll find the soldering iron less effective. It doesn’t have as much voltage as the solder gun which makes it more suited for low power jobs. Solder irons aren’t as energy efficient as the guns. They are slow in heating up, which takes more energy in the long run.
 forum activity
