Solve Drinking Water Problems: Water Looks Cloudy
Suffering the sorts of drinking water problems that causes water to become cloudy can be worrying, making it essential to find the cause. Understanding the types of issues that can cause cloudy water will ensure that you are able to quickly locate and rectify the problem, rather than put your health at risk.
Test
If you have discovered that you may have drinking water problems, you should begin with a few experiments. This will not only help you to determine the cause of the problem, but will also allow you to be sure that the cloudiness was not the result of normal bubbles. Fill a clean glass from a faucet using a low flow to reduce bubbles and check it for cloudiness after letting it settle. Follow the same process with the bathroom faucet to see of there is any difference.
Source
The source of the water used in your home can be the cause of drinking water problems. If your water is supplied from the mains, begin by checking whether your local water company are experiencing problems with the supply. These will normally be announced in the local news or on their website. If one of the steps of the water cleansing process has failed, you will find that debris can remain in the water. Drinking water problems can occur when you make use of a water tank that is not properly constructed or has been left uncovered, which will allow access for debris to get into the water.
Cause
Besides the source of your water, drinking water problems can be caused by other reasons. If you have had a water meter fitted, your water pipe will have been accessed during this process, which can result in dirt gaining access to the pipe. Living in a hard water area can cause deposits to build up on the inner surfaces of the faucets and pipe work, resulting in particles combining with the flow of water. If you notice deposits around the rim of the faucet’s spout, you will find that this is the problem. In very old properties, the pipes will often be made from metals that can corrode and result in particles coming loose and remaining in the water.
Solution
In the event that a water meter has been fitted or in the period after a burst water pipe has been repaired, you will find that leaving the water to run for a few minutes or until the water runs clear. This will be sufficient to rinse all the silt or dirt in the pipe and will solve the problem. Disassembling the faucet will allow you to clean it with a scourer or by soaking it in white vinegar. Draining the water tank to clean it will help to prevent the problem of cloudy water, along with ensuring that the lid is properly fixed in place. Alternatively, a water filter can be obtained from a range of household supply stores and can be fitted in place to trap any particles.
