Login Error
Close
Space Heater: Bathroom Warmth Made Easy
by DoItYourself Staff
A simple, inexpensive way to add warmth to your home without affecting your heating bill is to use a space heater in the bathroom.
Safety First
The safest types of space heaters are electric, especially for a small, enclosed space like a bathroom. An electric heater can be plugged into an existing outlet and will not emit any dangerous fumes or gases. The heat level can be adjusted for maximum comfort.
To avoid an accidental fire, place the heater in an area clear of potentially flammable objects. The front of the heater should face into the room with no obstruction, and all towels, shower curtains and even toilet paper should be kept away from it. Also, check that the heater you buy has an automatic safety mechanism built into it that shuts the heater off if it is tipped over. In fact, position it on a countertop to keep it sturdy and so that no one will trip on it.
As with any electrical appliance, keep water away from your space heater.
Heater Types
There are two different types of electric space heaters: forced air and radiant heat.
Forced air heaters operate by blowing warm air through a grill via an enclosed fan. This type of heater heats a room faster, but it may have a lower heat plateau and can be more expensive to run.
Radiant heaters work by heating up metal coils or rods, also contained behind a protective grill. This causes the heat to emanate from the unit slowly and continuously, resulting in a capacity for more heat overall. Radiant heaters use less energy because there is no fan.
 forum activity
