Login Error
Close
Spalling Concrete? Repair It
by DoItYourself Staff
what you'll need
  • Circular saw with masonry blade
  • Chisel
  • Hammer
  • Concrete mix
  • Drill
  • Paddle bit
  • Wired brush with scraper
  • Anti-rust paint
  • Bonding agent
  • 2-by-4-inch board
  • Plastic sheet
  • Gloves
  • Safety goggles
  • Wheelbarrow
Spalling concrete, or concrete cancer, is a cosmetic blemish to structures; spalling requires concrete repair to restore the concrete to its original condition. This article explains how to carry out concrete repair.
Spalling is caused by carbonation and occurs on the surface of reinforced concrete structures. Carbon dioxide diffuses with the concrete and reacts with the chemicals inside the concrete. This reaction causes the steel bars inside the structure to corrode and expand. If you catch the spalling in the early stages, the integrity of the concrete structure will not be affected.
If the affected area is minor enough, you can complete the concrete repair by fixing the reinforcing bars inside the structure and resurfacing your project.
Step 1 - Cut around the Spalling
Put on the safety goggles and gloves. Use the circular saw to cut 3/8 inch deep around the damaged area of the concrete structure.
Step 2 - Remove the Damaged Concrete
With your hammer and chisel, begin to chip away at the damaged concrete within the cut-out section of the structure. Remove the pieces of concrete out of your work space as you go along to expose the reinforcing bar beneath the damaged section.
Step 3 - Repair the Reinforcing Bars
Use the wired brush to scrape away all rust from the bars. If you spot more rust beyond the perimeters of your cutout, you will need to perform additional cutting to treat the affected areas.
Step 4 - Apply Anti-Rust Paint
After you remove all rust and corrosion, you will need to apply the anti-rust paint to the reinforcing bars. Apply one generous coat of paint and allow at least 10 minutes of drying time. Then apply a second coat to the bars to prevent future oxidation.
Step 5 - Prepare the Concrete Mix
Mix the concrete by adding the required amount of water, according to the manufacturer's instructions. Mix the concrete in the wheelbarrow. Use your drill with the paddle bit to keep the concrete mixed until you get ready to pour it. This technique will keep the concrete from settling in the wheelbarrow.
Step 6 - Apply a Bonding Agent
Apply a bonding agent to the walls of the affected area. This procedure is significant because it allows the old cement to bond closely with the cement that you will pour in the next step.
Step 7 - Pour the Cement
Pour the prepared cement into the cutout of your concrete structure until the new concrete is even with the rest of the structure. Use the edge of a 2-by-4-inch board, held at a 45-degree angle, to smooth the surface of the patched area.
Step 8 - Cover the Area
To ensure the patch cures properly, cover the area with a plastic sheet, which prevents the patch from drying too fast. Lift the plastic within 48 hours to mist the concrete with water to help prevent future spalling.
 forum activity
