Split Rail Fence
If you decide to put up a split rail fence, you will be pleasantly surprised at how easy it is to install. You can find the wood and fence posts needed at your local hardware store or lumber yard. You do not need any previous fence experience when you are ready to install your split rail fence.
Where Do You Use A Split Rail Fence?
You can use a split rail fence any where; it can create a ton of charm to your home. Most places you will notice a split rail fence being used is in the country. The split rail fence has been a great way for farmers to keep their cattle and other large animals secured.
The split rail fence needs little maintenance, does not need painted and will only require you to purchase treated wood or treat it yourself before you install the split rail fence.
