Login Error
Close
Stain Hardwood Doors In 10 Steps
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Sawhorses
  • Sandpaper
  • Stain
  • Sealant
  • Paintbrushes
  • Gloves
  • Clean Cloths
If you are starting an indoor remodeling project, staining your hardwood doors is a simple and effective way of updating your home.  This is a do-it-yourself project that can be fun yet time consuming, depending on the shape of the door and previous materials applied to it.
Step 1-Remove the Door
The first step you will need to do is to remove the door from the frame, assuming you are working with a door that you have previously been using.  This is done simply by removing the screws from the hinge and removing the hinge pins.
Step 2-Set Up Sawhorses
Set up the sawhorses and place the door length wise on top of them.
Step 3-Sand the Door
Using your sand paper, start to remove anything on the surface of the door.  Depending upon the detail of the door and any previous layers, this could take some time.  This should be done carefully and thoroughly.  Don’t leave out any crevice or it will show when staining is done.
Step 4-Apply the Stain
Once you have prepped the door, you are ready for the staining process.  Applying the stain evenly is very important.  You also must apply with the grain, as opposed to against the grain as you are staining, for best results.  Wear gloves to apply the stain.
Use your clean cloth and start by applying stain in even strokes; start from the center of one door panel.  Go from panel to panel and then to strip in between panels.  Last should come the molding inside panels, making sure to match the panels.
Step 5-Let Stain Dry
Allow first layer of stain to dry completely.
Step 6-Apply Second Coat
Apply second coat of stain exactly the same as the first layer.
Step 7-Apply Stain
After the second coat has completely dried, turn door over and repeat the entire process for the other side of the door.  Be sure to apply stain to match the previous side.
Step 8-Apply Varnish
Once the entire door has been stained, it is time to apply the varnish (sealant).  The best option is to spray on the varnish for the best finished look.  If spraying is not available, then you can paint on the varnish.  Be sure to apply two coats with drying in between.
Step 9-Reattach Hardware
After door has completely dried, reattach hardware using your screwdriver.
Step 10-Re-Hang the Door
Lastly, re-hang door in the door frame and enjoy your hard work
 forum activity
