Standing Seam Metal Roofing: Steel, Aluminum or Copper?
A standing seam metal roofing product makes a great option for protecting the roof of a home. Metal roofs are becoming increasingly popular because of the way they are built to last, hold off rain, and even keep roofs cleared off during the winter months. A standing seam metal roofing is a type of metal roof that has all of these qualities while also adding a design touch to the home.
Major Advantages of Metal Roofing
Standing seam metal roofing also has several other benefits that make it a popular choice among homeowners. Metal roofing has a great reputation in helping to keep roofing materials dry, but standing seam roofing takes this one step further. Because of the way that the seam is standing, rather than laying, the drainage is much better with the complete elimination of water seeping through a seam. Also, standing seam metal roofing is maintenance free. They do not need to be replaced, or repainted for at least 30 years.
Different Material Choice
For the homeowner who is constantly on the lookout for ways to improve their home, having variety in the different items is more of a benefit than it is a hindrance. Standing seam metal roofing is available in three very popular materials: steel, aluminum and copper. Depending on where the home is located, one of these materials will work best.
Steel Standing Seam Metal Roofing
Steel is a very hard material that adds to the overall protection that the metal roof will provide. Thin sheets of steel can add several more years to the life of the metal roofing because of the way that it will stand up to damage and weather without a lot of maintenance. Steel is a little heavier than aluminum and copper, so consideration must be given to the sheathing and bracing of the roof. Steel is also limiting as far as cost goes. However, this is outweighed by being maintenance free and lasting for several more years.
Aluminum Standing Seam Metal Roofing
The next type of material that is mostly used in residential type of metal roofing is aluminum. This type of metal roofing is mostly found in areas with mild weather where there isn't a lot of snow and ice and high winds. Aluminum will last for many years, but is lightweight and can bend, break, and crack rather easily. The cost is the major reason why it is so popular among small homes and outbuildings.
Brass Standing Seam Metal Roofing
When it comes to style, brass metal roofing is miles ahead of aluminum and steel. The great looks of brass, even when weathered, gives many homes a finished look that can not be duplicated. However, this style does come with a cost. The brass metal roofing is considerably more expensive than steel and aluminum. There is also more maintenance needed to keep it looking good and maintaining its strength and integrity. But, for older homes with a Victorian flair, brass standing seam metal roofing can add thousands of dollars to its overall value.
